610sm removal of chain guard on bottom of swingarm?
ricroc636
will any issues occur if i remove the bottom chain guard underneath the swingarm on my 610sm? the rubber inside is almost ground down. do you think anything bad will happen if i just ride without it completely?
Yes, bad idea! Remove it and tap the mounting tabs so it's in line with chain. You can add a washer on one side or the other to help straighten it out also.
