610 Brake fluid reservoir mod
BiG DoM
As many are aware the brake fluid reservoir on the RHS wants to interfere with the clutch cable - easy fix is to take the reservoir off and use a paintstripper hot-airgun to carefully heat the plastic locating tab and bend it backwards. Hold it in place till cooled and sorted. (You can mask a bendline with some card or masonite if you want but not really necessary.) Quick and easy fix!
