Quick question, finished a cam chain job on my '01 610 so I had to remove the battery box. Now when I hook up the battery I am getting precisely zero, not a sausage. Everything is totally dead, not even a spark from the terminals, like the circuit isn't complete.
What actually prompted me to undertake the cam chain job was that the ignition coil failed so I had ran the battery flat trying to start it, then thrown it in the shed for about a month before charging it with a regular car charger. This may or may not have had an effect on the battery.
The charger is a basic one so it indicates with a light whether the battery has charged or not and the light shone brightly when I hooked it up to test it, so I think it's okay, I just need to dig my multimeter out of the shed to confirm.
Just to rule out the wiring can someone confirm that this is correct:
This starter relay only has one fuse in it, the other is a blank slot for a spare.
The battery positive goes to the terminal marked "M" and the starter wire goes to the terminal marked "B".
There is a small neutral wire as well as the main negative from the battery:
That is all the wiring I can see and according to my understanding of the wiring diagram it is all correct. I figured this post will be useful for the images even if no one can help me with my particular issue.
