mr stainless
ok here goes ....
I have a 86 CR 500 bottom end with an 84 barrel on it with 5 speed box . Now I lost 3rd gear last Sept so after taking it apart I was supposed to go to the Telford show and see Andy at HVA but for one thing an another I couldn't go but I did pick up another gearbox off ebay with casings .
All good I hear you say ....yes to a fashion ....all the gears are definitely in better nick than mine and so are the casings but ...the new casing doesn't have the extra hole at the top and according to the number on the case its an 86 ..... why would that be !!
Now I also have a problem with that the gear on the back of the clutch unit is ....lets just say not very good ..... but Andy doesn't have one and its liable to be bloody expensive if I find one ...
So enter a 1993 te350 motor..... now this started as a hunch that the case would fit so I would have a better way of servicing clutch and bingo it fits a treat ...so then I have this idea of fitting the whole clutch unit !! no that wont work but the 350 motor does have an immaculate 6 speed gearbox in it ....will it fit me thinks ...well blow me it does .....
So what I want to know is .... why has the 86 casing missing the extra lug !!
and secondly is there any reason why the 350 gearbox and all its other bits will not work properly... it would solve a big problem and has cost me very little to get this far ...
many thanks
graham
many thanks
graham
, it's so simple , most wouldn't have thought of it.
