4pt vs 12pt injectors and clogging?
R_Little
The 4pt injector on my 2010 TE250 seems to work fine even with a lot of use on it.
I've wondered if the larger holes in the 4pt leave it less likely to clog?
I really do not think it matters. There is screen on the inlet side of the injector with very fine mesh. I think anything small enough to pass through the screen will pass through either 4-port or 12-port opening with out an issue.
Makes sense.
Then it must not be the injector that clogs but the screen.
Or maybe the injector holes gum up with ethanol muck.
