For a standard 430:ii was a long time ago, but i am pretty sure it was the standard bore but they lengthened the rod. I dont remember what they changed on the cylinder/head to accommodate the longer stroke.
Interesting, Factory 4510 !I sent my crank and cylinder / head to them so it really wasn't a "kit"
It was definitely the stock piston, and I thought I remembered the weld were the rod was lengthened. I think the reason they need the cylinder was to put a relief cut in the bottom of the liner to get more clearance for the rod but I sure don't remember how they allowed for the increased stroke. I also had a Can AM 250 GP (rotax rotary valve) and between that engine and the 470 those were about the two best engines I have ever ridden. The 470 conversion did make the weak brakes feel even more inadequate. I had ridden a 500 CR with the dual leading link front brake, and with the shoes properly arced in and adjusted it stopped much better. If I was to build a vintage MX bike, the 470 would be a good choice to go up against the Maico's and Honda's.
Another option is to contact crank works. They can make you 4 custom sized rods.
Minimum order is 4 for like $ 250 each.
Then get them to move your rod location on crank.
I almost did that to make a true 175 newer husky.
