I set out this morning to add a kickstart to my bike 2003 model elec start only, with the help of some used parts ive collected recently from a T.C model. I stripped the clutch/basket out and then discovered that the main engine case whilst looking similar must be slightly bigger around the kickstart housing to house the gear and it can't be done so I bolted the clutch back together tried the lever a couple of times didn't feel right so I stripped the clutch off again hoping to see a schoolboy error somewhere but it looked all o.k. Refitted the clutch tried the lever, felt stiff then lost all pressure. Noticed some fluid leaking down the clutch hose obviously split under force so I stripped the slave cylinder off to have a proper look and found a mangled O ring and the circlip busted out of the slave and sitting inside the engine case including bits of the metal lip from the slave cyl that was holding it in. So I'm now into a new clutch hose and slave cylinder but before I go and break the new ones I can't figure what ive done wrong with the clutch can anybody advise me please hopefully from the pictures?
still struggling to find a torque setting for the clutch bolts each manual I've found on the net tells you to torque them but then only gives the centre bolt setting. I've ordered a new clutch hose and managed to peen over the end of the slave housing just enough to hold the snap ring with some of the Lip that was remaining, need a new O ring but it might just hold enough to test I haven't got a problem with the clutch plates etc once torqued correctly. I'm looking at an Oberon replacement slave cylinder about £100 in the U.K so I'll be careful not to blow that apart
Thanks for the suggestions and Happy New Year!
