Hi I've bought this bike recently took it for a short test ride all seemed fine but haven't ran the bike much as ive had various bits stripped out to do different jobs although nothing to the cooling system which is untouched. I've got the bike back together now and had it running at idle for 5 minutes or so when I noticed fluid dripping from the rad overflow followed by steam. I've drained and replaced the coolant and had the same thing happen. Water pumps operating correctly. Ive read on the forum about running lean causing this and whilst it is probably running a little lean at idle I cant believe that alone would cause the overheating in just a few minutes or could it? Im thinking it might be the headgasket? Although the coolant pipes become firm but not rock hard and the plug whilst a bit pale is 'dry'
Any suggestions as to a definitive test on the head gasket was thinking about the dip test kit for coolant used on cars?
Regards AL
Regards AL
