450 smr engine grinding
kyleross
Hi guys
My 450 smr was running perfectly and all of a sudden I have a heavy grinding sound coming from the motor. I drained the oil and on magnetic sump plug I had the usual small fillings.
The motor atill pulls very strong and no funny sounds other than the fact it sounds like its grinding big time.
Anyone have any idea what is wrong?
Thanks in advance.
check location of noise, can be the breather cyclonic disc on the end of the cam shaft when it comes loose and the hole gets out of round the thing makes an ugly but relatively harmless noise. It can also be the auto decomp cam assy. But thats all up on top.
Start it up and use a long skinny screwdriver mashed into your ear and put the tip on various spots on the motor: top end, head, cylinder, lower end engine cases, etc. You might be able to narrow down the search, Like Robert said, easiest stuff would be right under the valve cover.
