449 jd tuner
rappster
i'm new to the fuel injection world and have been reading about the JD tuners, however is there anyone putting them on the 11 TC 449's, all i hear about is putting them on TE's. also any info on the Ibeat? is this a must or don't worry?
thanks
Husqvarna racing team used powercommander 5's on the TC449. JD's are built for the TE/TXC, not sure if it will go on a TC or not.
Stephen gets 56bhp using one. The bike is 50hp stock, no idea what the bhp is. You can achieve more hp from a pcv, but its expensive and more complicated than the JD.
The JD unit is more popular because of price and simplicity. It is east to adjust and is set up to make adjustments like a carb that most people understand. The PC unit works best with the auto tune and can give more HP with tuning help like a dyno, a map from someone else, or by trial with the autotune. The question is how much do you want to spend and how much do you want to fiddle with it ? I put the JD on my bike and it is still running the stock settings because I just like to ride and do not mess with stuff hardly ever, heck my suspension settings are still stock.
one question i have is does it help improve with the starting, mine seems like it takes longer than it should. i'm not looking to gain a ton of performnce,
What kind of fuel/additive do you use? What kind of spark plug do you use?
Two things that works for me is using Startron which I am sure you have used before. Stabilizes your fuel and cleans the injectors (has same ingredient as Amsoil, Lucas, many others. plus has an enzyme in it).
And iridium spark plug # NGK CR9EIX (3521) which yields a hotter spark and fouls less without using a hotter plug or changing your ignition.
I hope it's as easy as putting a new plug in it. At GNCC's they use a dead engine start and I'm always the last one to get going.
