449/511 owners, check your clutch hose
Huskynoobee
CH Sponsor ZipTy Racing
Staff member
Whilst out and ripping about yesterday, I was taking a water break and looking the bike over. I noticed the plastic retainer near the steering stem that keeps the clutch hose and wire loom in place had opened. I closed it back up and decided to check the routing since it had probably changed some.
That's when I saw the toasted spot on the clear covering where it runs behind the header. I took up the slack at the top and a little near where it goes into the side cover. I suggest you check yours as well. For added security I zip tied it to the water hose but made sure to not make it too tight so they don't pull on each other. Just enough to keep it away from the header.
I installed tall flexx bars and ended up raising my bars up 2.5 inches higher than stock and noticed the issue with the clutch line. Taking up the slack cured the problem for me.
Which Flexx bar bend did you install and do you feel the flexx bars were worth the money?
Thanks
