firecrackerkid
Ok I got it running fair today. Here is the scenario:
1978 390 or. New engine. 38 vm carb. 40:1 golden spectro with 92 e0 premium. Tried procircuit recommendations, way to rich, I think. Here is where I am with jets at this point.
Main 390
Jet needle 6f15 clip 4th from top
Needle jet Q-8
Pilot 45
Airjet 2.0
Air screw 2 turns
These are the symptoms. Idle screw must be turned in almost all the way till the spring coil binds.
It will idle though. The slide is about 1/4" up on the back side. This can't be right can it?
When riding it is blubbery from 1/4 to 1/2 throttle until the rpm's pick up then cleans up and runs pretty good. I am getting a handle on how the pilot jet and air jet work but the needle jet has me confused about where to go next. Seems like still too rich. I have a p8 which came out if an it465, maybe i will try that next.
Thanks in advance for any clues provided.
geary
Main 390
Needle jet Q-8
Pilot 45
Airjet 2.0
Air screw 2 turns
geary
