310 output shaft oil seal
Tim Randall
Hey guys,
Changing the chain and sprockets on my 310, while in at it I am changing the oil seal behind the countershaft sprocket.
Quick question, behind the sprocket is a bush, this is what seals against the oil seal. What's stopping oil from leaking through the bush?? (between the bush and output shaft) the other end of the bush sits hard against a lip on the shaft but still a chance of oil to leak by?? On other bikes I have seen an o-ring sealing the bush to shaft, what makes the 310 different??
Cheers, Tim
