bigcahunak
Well, the auto clutch override feature of the dyna-ring, technically overrides, but not really as good as... regular clutch.kzoo;125398 said:So it sounds like some riders like auto clutches and some do not; nothing in particular about the dyna-ring proper... Interesting, for those that did not like it, even the clutch override feature did not help?
Its hard pulling, the lever is far out forward and lacks any feel. Comes to think about it, its that when you finally use it when you have the auto clutch is when you really need the feeling to lift above larger obstacles... you pull that far out lever in (realizing you put more effort in holding the lever than the bar...) then releasing it to discover the clutch is still disengaged cause you didn't rev the engine enough for the auto clutch to engage as well, which makes it tricky cause too much revving and clutch lever releasing might cause what is known to most of us as... back flip... but for now its no back flip, cause your front just got stuck in that 1.5 foot high rock which you couldn't lift over in first attempt, bringing your confidence down and sending you 3 points about for 2nd attempt... till then you just boil your clutch and engine some as its on a constant slip between the plates till you finally get moving.
Our race season is just rapping up too.
