Ive checked the carb all seems ok, replaced a jet that was damaged. compression is around 120psi has a new piston and rebore so not yet bedded in. there is a good spark.
but all I am getting is a slight rumble, not a bang!
seems like it may be over fuelling as exhaust joint is wet.
any ideas?
my old AJS stormer (2 stroke) wouldn't start if crankcase had fuel under the crank, but then it had a drain plug for this purpose. am I looking at the same thing??
any ideas?
