• 4 Stroke Husqvarna Motorcycles Made In Austria - About 2014 & Newer
FE/FC 2015 FE 350 TPS settings
Octane is the ability of a fuel to resist knock, and high-compression engines tend to knock more. The obverse of that is that lower-compression engines can run on lower-octane gas. Air is thinner the higher above sea level you go. Less air going into the cylinders means less pressure at top dead center when things go bang. It's a lot like lowering the compression ratio in the engine, reducing the need for high octane. Cars will run just fine on lower-octane fuel when they're well above sea level--and all of those states are.
It's not paranoia, it's only advice. You will obviously modify the tps regardless. But others who read this thread will have the opportunity of a qualitive choice before taking a risk.
With after market exhaust you are allowing more air to flow through the engine, so to compensate for the leaner condition, you will need to add more % of fuel to your mapping.
