Coyote
Hi , I wonder if you guys can offer advice?. I have a lovely 2013 WR300 with Pro circuit Racing exhaust, 6 speed gearbox, Keihin PWK38 carb.
Some issues:
I notice lately that at HIGH RPM it has a severe splutter / misfire-the last time it did this was when the Base gasket leaked coolant into the crank case. The coolant level seems OK this time. And there is no white smoke.
It is not pulling like it should at all.
Could it be jetting, air leak, power valve etc?. Plug seems OK as well.
I did find one of the breather pipes on the carb (It has many!) blocked with mud, and cleared it-still same.
Could it be ignition unit?.
I love the Bike, but it is certainly hard to start with the headlight ON!..(I have to turn off the headlight and blip the throttle)
The Clutch-Oh boy!.. I have NEW fiber plates fitted, the FREE PLAY is OK, I can physically see the clutch HUB pull away from the basket. But it STILL DRAGS!.. I am using Motul Gearbox oil-10W40.
any advice?.
Cheers,
COYOTE
Some issues:
any advice?.
Cheers,
COYOTE
Hi Guys, Thanks for the excellent replies!.
