2013 txc310r oil screen
Jacob Sedlock
Hey all spent a good part of the day trying to fix what should have been a 10 min oil change. Basically oil screen on bottom of motor slipped back in the hole all by its lonesome and must have a small kink in it or something, it doesnt want to come out. Does anyone have any tips on the best way to get it out??
http://www.harborfreight.com/4-piece-pick-and-hook-set-66836.html $1.99
@tinken found some of those and FINALLY got it, but its butchered up... i heard on here somewhere that some people don't run it, what does it actually do? It is an open ended filter after all.
FYI,
I use a CLEAN M8 x 40mm set screw to remove the screen. Just slide it in, hold it gently on an angle and pull out... screen comes with.
Edit: could be an M10 screw, but what ever fits with a bit of wiggle room.
Doubt it would get a butchered screen out tho...
