2013 TXC/TC/TE 250 and 310 throttle position sensor voltage
Matthew525
Been doing a lot of work for maps in different weather, but am now looking into throttle position sensor voltages.
Currently I'm running .649 v at idle. I'm wondering what the concensus is on the optimum number and see the effects on the fuel map.
I think there may be some ignition timing bennifits with a hight number, but wanted to see if anyone has played this game already.
OK that's great!
Any one done testing on the effects of other settings? How consist are they from the factory? Is .65 nominal?
Easy to set to .688, but want to understand a little more to dial it in for my bike as I understand it makes changes to both fuel and ignition timing curves
FYI: update
I got documentation right from the Husqvarna Service tool.
They say set to .680v or as close as possible.
Also it is necessary to set the idle to 2150 reset the adaptive learning in the ECU and then allow the bike to idle for 5 minutes without touching the throttle to relearn itself. At the end, readjust idle to 2150 rpms.
