2013 TE449 questions
The linkage is substantially different though, so I think you may want a different spring rate....but it doesnt hurt to give it a try if you already have the spring.
Ya it is a 6.5kg on my 310 now. Might be too stiff? Racetech calls for a 6.1 on the 449 for my weight class.
Big question now is. If I open the air box, install the jumper or switch and flash the ECU, what mpg would I expect to see? I get mid forties on my powered up 310 now and have a range of 90 miles. I need the same or better with the 449/511 to go on trails I like.
I think I put a 6.0 on my 511 and Im pushing 300lbs fully geared up. If anything I find Racetechs recommendations on the stiff side.
Yes RT calls for a stiffer spring on the 310. Must be the straighter orientation of the shock on the 310 that requires more spring than the 449/511 platform.
So 449 or 511 that is the question I am facing now... Only $300 more for the 511. I may kill myself on a 511 though.:eek:
The 511 is the premier model unless you are racing in a specific class. Milage is around 41mpg with map#3 installed.
The only difference is the 511 has 27 cc more displacement. If that is worth $300 then you are golden.
Cost a lot more then $300 to make a 449 a 511 later on.
If the 511 wasn't $3000 more when I was looking I would have gotten one instead of my 449
Yeah as far as TE's I'd go with a 511, unless racing class is an issue. Then I'd go with a 511 with a 449 sticker lol.
I've spent a ton of time on a TC449 and only a short section on a 511. The 511 had sprockets for much faster riding so there isn't much I can say about it. I've read that the torque is the real difference. Hurry up and get one, you may not have a choice before long ;)
