Rizzkid
Just did an oil change and valve adjustment and wanted to offer some tips.
- valve adjustment is easy . I needed to go to a lower intake shim from 1.7mm to 1.65 to bring it into spec. The biggest problem was connecting the gas elbow under the tank after. I used the ZipTY racing aluminum elbow and it was a BITCH to get it connected. I finally succeeded by elevating the tank sightly with wood and centered the connection the best I could. I made each white tab centered on the connection before I forced it gently with channel locks. then pushed the connector in by hand as far as it would go. Then I used channel lock pliers with the metal covered in several layers of electrical tape as not to damage the plastic fuel line which goes into the gas elbow under the tank. I am really mechanically inclined and this was a real PITA.
- oil change tip. I finished the oil change and it was easy. When I was dumping the oil out of the pan into a container I noticed a copper washer. Oh No! This copper washer goes on the oil drain plug (other end goes to a rubber hose and is the oil vent to the frame). So when you drain the oil, look for the copper washer and you wont have to re-do the oil change like I did.
PS went form a 47 rear sprocket to a 50 rear, so far it kick ass and can easily wheelie with little effort. Cant wait to trail ride again soon.
