sailah
Long story short I buried my TXC in some water this weekend and decided to change the oil and coolant to be sure. Oil and coolant were fine and I decided to check the valves since I had it on the lift. Lost one of the stupid "half balls" down the cam chain tunnel. Grrrrr. Anyways I got the ball and am in the process of putting it all back together.
Found it
So it's been awhile since I did a valve adjustment and I was surprised at the results I got. just as some background on what I did, I locked the crank at TDC using the detent and locking bolt on the bottom of the engine. used metric feelers between the cam and bucket/follower and did each valve twice just to be sure. Below are the measurements I got.
FRONT OF ENGINE (L R)
Exhaust .28mm .24mm
Shims 2.60mm 2.64mm
Intake .25mm .22mm
Half balls 5.05mm 5.07mm
The factory specs for the TXC are shown below
My question is that the exhaust is pretty close the right exhaust valve is a little tight. So in order to loosen the valve to the loose end 0.24mm-0.30mm = -0.06mm. So the 2.64mm shim ideally would be a 2.58mm shim. Of course they only offer them in the 0.05mm steps. But if I put in a 2.60mm shim that should get me 0.28mm clearance which would match the left and be as close as I can get with factory shims.
Can someone check my math and rationale?
Second more important question is the intake. They are way off apparently. I need to close that valve clearance 0.15mm on the left and 0.12mm on the right. Which should mean that there are 5.20mm & 5.19mm balls in each respectively. That seems like something is not right. It also looks like it's very close to the TC engine in specs and I'm wondering if it should be that way in which case I'm already in spec.
I've always thought that valves got tighter as they get older, and since the bike runs so well, I'm inclined to leave it and let it tighten up over time. I'd hate to set the valves too tight and have it not run well and have to take the bike apart again.
I called Halls to order parts and spoke to their service guy who said set it to 6 & 8. Which makes no sense. Before I took the engine down it ran perfectly, maybe a couple bumps to the starter to fix it. How would the valves get that far out of spec in the low hours I have put on from factory?
So anyone have any advice? Thanks
Found it
Exhaust .28mm .24mm
Shims 2.60mm 2.64mm
Intake .25mm .22mm
