I finally got a good ride on the normal single track with the new fork setup. The conditions were less than ideal as the trail is dry again. Major improvement with the drilled free pistons and softer main springs. Front end was more compliant and held a line much better, it did not push or climb out of ruts. I put the improvement on par with the improvement of the addition of the Merge racing springs. Next time you have your forks apart drill the 4 holes and you will be impressed.
Hi there i drilled the 4 holes (3mm) as read the 'later' KYB needs this and the earlier has 2x 5mm but ive found out the forks are the same as YZ250 06-10 so are they earlier or later? Also the drill holes should only do their job if the seal allows oil to pass it dont they?
I really want to try the merge racing spring but im in the Uk and its costly.
I have a set of .43 springs to go in tomorrow and will replace the bushings also so fingers crossed she rides good and my arms last longer!!
Did u keep the valving/shim stack the same thanks?
