2012 TE310 kick starter & throttle issues
Phil Lamb
New bike. Could not get kick starter to work. E starts fine. Removed foot peg, which gave a bit more lever movement, started fine. So changed spline alignment on kick starter, works great. I assume lever is factory installed. Any others with similar experience?
Re abrupt throttle at low rpm. Installed G2 Ergonomics throttle tube witn 400 cam. Huge improvement. Is this related to, or the actual, low rpm snatchy throttle EFI issue so often referenced in these forums?
Bike has power up kit installed.
PL
