2012 TE Will The TXC # Front Plate Fit?
AllOut84
I have a 2012 TE 310 and I will be doing some harescrambles this year and don't want to end up destroying my TE headlight set up, what I am wondering is will the TXC front # plate bolt right up to my TE or will I need a few brackets + the plate?
Thanks
Thanks
As long as you have #30 in the diagram above that mike-ak posted you will just need the plate. I swap my light and number plate around between the WR, TXC, and TC quite often. Quick and easy. You doing ECEA or NEOC races?
Awesome thank you everyone..
I mainly do the NEOC races and maybe 1 or 2 ecea harescrambles and shooting to do an enduro or two and a dual sport ride this year
Yep, I have one mounted up to my 12'IMG_20130212_191305.jpg TE310 I just had to make a little aluminum connector to lengthen up the connector no problem at all. Rear fender fits up no problem too.
I just came across this thread, I'm looking to swap out my headlight and use a number plate on my 09 te510. Where can you order an OEM TC or TXC number plate from? Or what are some good aftermarket ones and where can you order them?
Thanks
