2011 TE511 engine Ticking noise...
JMK
Hi guys,
I was going for a slower technical ride today when i noticed a ticking noise under acceleration... wondering if any one has experienced anything similar with their 449/511?
the bike is sub 5k kilometres, and has always been fed 10w 40 synth oil- regularly at that.
thanks for your time =)
i started it again this morning, and dicovered that its the clutch making the noise. the noise goes away when the lever is pulled in and is only noticeable when taking off. i know that suzi sv650s and some other bikes do this, and that on those bike its nothing to worry about... any advise is really appreciated
cheers
My 511 my12, also is louder with the clutch out, much quieter with it pulled in, I have noticed the same with
several other bikes I have owned, never had a problem.
ok, yea after reading around i was thinking it may be something like that... first issue on an otherwise great bike
thanks for the reply
The 449/511 DDS clutch is pretty bullet proof if it remains under oil. The revised Husqvarna oil levels are too low to properly submerge the clutch. 1150cc of 40 grade oil quiets the clutch.
Mine is noisy too, the additional oil helps, but it's by no means quiet. I thought that my valves were under attack when I first heard it, but since I also have an SV, I pulled the lever in and breathed a sigh of relief!
