2011 TE310 starting relay problem ?
Snail
Dropped my 310 today and afterwards it would not go,
Had power to the dash
No fuel pump priming so couldn't kick start either
Hitting the start button caused all power to go off momentary.
After removing the side cover and checking fuses and connectors one of the other guys shorted a screw driver across the relay and the bike turned over just fine.
Immediately after this everything was back to normal with the starter and fuel pump working fine.
I dropped it again later in the day and had a repeat of the problem but a solid thump to the cover plate beside the area of the relay got it going again.
Not sure if it is a looses connection or the relay playing up.
Any others seen this problem.
Relays can cause intermittent problems. I say check your connections at the relay both the ones that power the relay and the ones that the relay passes power to, in other words all the connections at the relay. If that won't solve the problem, replace the relay.
fuse is not the problem or shorting the relay wouldn't have worked. The relay either has a loose connection or it's sticking internally. Check the connections, if snug, etc... replace the relay.
Over the years I've learned some basic rules for trouble-shooting: 1) Never assume anything, 2) Try the easy & low cost things first.
The cracked fuse problem has burnt several riders. Fuses are easy to replace and should be in your trail bag anyway. I'd start with a swap of the fuse.
