2011 Te310 - Small Throttle Opening Issue
Mikolaj1618
Hello, everyone
I have some problem with injector system (i think...). But from the begining, aproximitly 30 sec to one minut after start motor (start normaly) when i open throttle a litle bit there is a moment when rpm falls (engine off if i hold it for a while). When i open throttle more then passes through this state and rpm go up normally.
If engine works about one minut (aproximitly) everything is back to normal and throttle works fine. But it's enough that off engine, wait a moment, start it again and problem back. Regardless of whether engine is cold or warm.
Firstly i though it was a problem with air filter oil (to much). But i instal brand new filter with less oil and it not works.
I try to adjust idle but i can't get over it... it works the same at 1800 and 2500 rpm. By the way i cant set 1600 rpm acording to manual. i managed to 1750.
I would be very grateful for any advice, maybe do you have some experience or maybe it is normal in this model ?
Regards
Mikołaj
Might be you need a TPS (throttle position sensor) adjustment. This is done using iBeat software connected to your warmed up bike. A shop may have it and many here have their own. It’s a little like a small timing adjustment.
