2011 te310 engine fail
josh310
i went riding today and on the way back to the truck the bike was trying to die on me and throwing a fail. It would just do it for a second and then the engine would pick back up. Has anyone encountered this before. I have read so temp sensor issues but what are the symptoms of a bad temp sensor? I did go through so deep creeks but i have been threw them before and never had a problem. I also sealed my coil up so water couldn't get in it.
yes sounds intermitant: wet something, loose something, start at the battery check connections fuses and keep headed toward the coil connections. Some xlite owners have tried to protect the coil with sylicone and splash guards. Dielectric grease helps some on connections.
Had similar issues to that and it ended up being the stator, You can tell its the stator if the bike does it after getting very hot..
I also had the problem of the battery coming loose and the cables grounding on the frame
hope this helps!
Ride On!
