Aaron8
My clutch is very grabby and uneven when cold. When moving from a stop in first. Once engaged it's fine. Is smooth as soon as normal op. temp. is reached. Is this normal?
Also, fully warmed, the clutch has a very narrow, smooth engagement range at the lever. The lever's almost all the way out at full engagement.
1. Is there a way to bring the engegement range closer to mid-lever stroke? The adjustment on the lever alters lever reach, but nothng else. The reservior plunger has no adjustment.
2. Can the range of clutch engagement be widened somehow?
Other than these things, the clucth works just fine.
Thanks, OHR.
