robertaccio
My TE310 has been running a little wierd on the last 2 rides and not starting as well as usual. I thought it was a fuel related issue, but appears that is not the case.
Then yesterday I had to ride my ex-RM125 (which aint a bad thing) because my TE was dead, when I kicked it the lights would come on for the kick then die right out and of course the F.I. pump could not get fuel to the injector so I parked her.
Got home and yanked the Ballistic 4 cell , cleaned the visibly corroded terminals and installed my OEM YTZ Yuasa she fired right off, but then it became intermittant with key on all was dead, the ignition relay seems to be sticking on and off when I cycle the key. Seems like an easy troubleshoot op.,
I will be back with her later and 2 moro morn to finalize the fix. Most any corrosion on the bike can only be 99% from me washing (she has not seen too much water on the trail, only a few instances)
So nothing new, as stated before here on CH the 11 model TE310 will not run/well with a bad battery/connection.
