2011 TE250 dash stays on, pls help
jetmani
Everytime I wash my bike the dash stays illuminated and the low fuel icon appears even with the key in the off position, I have to disconnect the battery to turn it off, once the bike dries out it is fine.Can anyone tell me where do I start looking first to fix the issue?
cheers.
you are probably getting water inside your dash or your ignition switch...- If you are using a pressure washer- don't- (or be real real careful with it)
But the real problem is, I would think that you have water getting in and shorting something :excuseme: making a connection and making the bike think the ignition is in the on position. I would start by using dielectric grease on one component at a time and washing in between to try and figure out when it happen's. By process of elimination you should be able to figure out where the water is getting in and what components it's effecting. Then you can figure out how to seal whatever's open for good once you know what the problem is.
You should dielectric grease everything reguardlsess of if you think they need it. Better to have it done then need it done after something's went wrong. I'd also clear silicone around the opening of the ignition switch where the wires go through.
