2011 TC 449 issues..HELP!
RonDog
After only about 8 hours, my TC started spitting out oil. From what I can see poaaibly from the breather tube into the air box, I can't seem to find any other possible place, I tore this nightmare down to the engine, the wire harness is soaked..im left scratching my head. It runs great, I just have to find this issue is...Possibly crank seals? any thoughts?
P.S. I am a vet pro..and I love this bike, once I learned how to ride it...the handling is better than any other 4 stroke I have owned!
http://www.cafehusky.com/threads/ziptyracing-billet-oil-catch-tank.32656/
resizedimage_1371863643617-1428780026-jpg.27746
The bike can't handle full oil capacity and spews out. The picture above is the full zip-Ty kit that allows the bike to keep all of the oil and then some. Oregonsage tested out just a part of the system (forgot what it's called though) and after that simple mod he hardly had any oil seepage. Tinken helped develop it all and I'm sure he'll tell you what part it is to order. The guys here tend to fill the oil up until half way up the sight glass so it doesn't spit oil out. It's bad for obvious reasons though. Even though they haven't had issues though. Good luck, it's the best bike I've ever ridden!
I bought the tank, breather & oil fill cap, but if you just put one quart in it when you change your oil,
You will be fine. Clean that air filter while your at it.
