Could someone let me know if the SMR 511 has the same maintenance intervals as the TE? I'm assuming it would (oil & filter every 500km/10hrs, valve clearance every 1500km/30hrs, tear down the motor every 3500km/70hrs).
an incredible story, Husqvarna, and not this year, to be more sustainable.This is from a PDF of the 2011 TE/TXC 449/51170h - 3500KMReplace the followingvalvestiming chainspark plugpistoncrankshaftcrankcase bearings
Check the followingvalve springsvalve spring retainers & colletsvalve buckets and rocker armcylinder headcamshafttiming chain slidertiming driven geartiming drive geartiming chain tensioneroil pumpprimary torque limitercheck some clutch stuff
Thanks!
Are you serious....Oil chainge every 5000km, so you have chainge oil one time that KM reading. Thats lots on KM berfore you chainge oilOdd? i own a SMR511 2011(in Australia.) My service are 1000km for breaking in period. then every 5000km for oil changes. the Dealer ship said they barely have to touch the valves even at 15,000km i've put 5450kms on mine so far and running awesome! Has full pipe on it with Australian husqvarna racing tune happy as i can be.![]()
Its what the dealer tells me But because of the tune i have on it Its a lot lower. i keep a close eye on it Not like i flog it every where i go full throttle no need to do that 100km change.Are you serious....Oil chainge every 5000km, so you have chainge oil one time that KM reading. Thats lots on KM berfore you chainge oil
