125-200cc 2011 CR150 Rear Wheel
Travis616
I found this interesting, I measured the spare rear wheel I have for my '07 Honda CR125 and it measures the same everywhere other than the sprocket needs to be moved out 6 or 8mm (about the width of itself). The wheel is an excel that uses different bolt on carriers to use the same base assembly between different makes/models. I will have to see about making a custom one the little bit wider and I would be in business!
