2011 630TE questions
Newfie
Hi, I'm a newbie to this site. Trying to get a few answers about my new 630! Is there any benefit to removing that black charcoal canister on the right side of my bike? If so , what do I do with the vacuum line coming from the engine to the canister ? Also the 2.2k resister I will be installing when removing o2 sensor, which wires will I jump with it?
The benefit of removing the charcoal canister is that it eliminates a big hunk of ugly off of the bike.
Some people put a vacuum line cap on the nipple that is left sticking out of the engine. Some people remove the nipple and plug the hole with a small bolt.
I'm not exactly sure which wires to jump. I bought the ready-made jumper plug and just plugged it in.
There's a very detailed thread specificly for the DIY power up. Vacuum to head gets pluged. Vent from tank rerouted like the over flow. The resister plugs in where the wires lead from o2 sensor. There are mod to airbox that will help and aftermarket cans are a plus. A lot of the 630 guys will say the JD tuner is also a big help! Good luck and enjoy!!
Thanks guys.... PU kit done, canister gone, airbox stripped! Bike is running much better now, and much more power! JD tuner, or power commander ?? Sounds like JD is most popular choice! Any suggestions on a pipe?
Unplug the O2 sensor and jumper the plug that goes back to the ECU with the resistor. Wrap with electrical tape and you should be good. Bike will run a lot better, but if you really want to unleash it, do this
Take baffles out of air box
Leo Vince pipe
Power commander and auto tune
Feels like it makes 15 more hp
If you're happy with that, just ride it. The only reason I put the Leo Vince on mine was for the weight savings.
