2011 449 injector voltage?
BC61
I'm having issues getting a 2011 449 started. It is not receiving any fuel in the cylinder. HST system checks where done and nothing came up. Fuel pump pressurizes but nothing sprays out of the injector. I'd like to bench test/clean the injector but need to know the voltage necessary to open and don't want to fry it. The positive wire to the injector is putting out ~10.5 volts when cranking over. Does anyone know what the correct voltage to the injector is supposed to be?
I used a 9v battery to open my injector, not the most correct way I realize, but it worked....
12 volts. Use a syringe and acetone. Force fluid through in both directions, tapping the injector on and off, do not hold on.
Took my Honda (Also Keihin efi) injector to my local efi car specialist. He plugged it into his test bench, took 5 mins & he wouldn't take money from me as it was so quick. Proved my injector was ok.
