2010 TE310, won't start hot
R-Man
My friend's 2010 TE310 would not start today after stopping for a short break - it ran fine right up until he shut it off and then it would not start for about 45 minutes. Then it magically fired right up, obviously something cooled down. It happened two times today. Anybody had that happen and have the answer ? The bike only has about 200 miles on it. Thanks
Make sure there is coolant in the rediator.
make sure you have a working spark plug-sometimes they get difficult when hot. Also make sure spark plug boot is on tight
check oil level
It is probably not withstanding the above a fueling matter and if this continues its a matter of getting back to the dealer to sort out.
Sorry - yes, it cranked over fine. It sounded like it was priming when he turned the key on. Could smell fuel after a bit, so I believe it was getting fuel. There was not a hint of firing until after the cool-down, so I am pretty sure it was a spark issue. When it did start, it fired right up normally. The fuel tank was almost full, oil level was good.
If after the ignition is off and he turns on the starter you hear the fuel tank pump "prime" then it could be a bad temp sensor. If it doesn't prime or the pump is struggling to prime then it's the pump. The pre 2011 Husky's were notorious for faulty fuel pumps and in hot weather they gum up and don't prime the motor correctly. I had that issue only in hot weather and replaced the pump...now no issues.
