2010 te250, clutch adjustment issue
Te250Gary
I have a 2010 te250 and I cannot figure out how to adjust the clutch.
The engagement point for the clutch it right at the end of travel on my lever, I'm afraid the anymore wear in the clutch will cause it to start slipping.
How the heck do you adjust the hydraulic clutches to change the engagement point closer to the handle bar?
The only adjustment I know of is via the lever which should have reach adjustment, not aware of anything else adjustable.
Have you worked out what's wrong with it? I am having the same problem with mine. Was told by couple guys I was riding with on weekend that there is no adjustment and it may be worn and needs replacing
Make sure you have corrrect level of fluid in clutch resevior. The master and/or the slave cylinders can leak.
I don't think anything is leaking. If something was leaking I would think the clutch pull would become further, Not shorter.
I replaced the clutch, it was super easy and fast. And that did not fix the problem. The old clutch had tons of meat on it.
This is a most annoying issue.
I had this problem when I installed thinner, Honda CRF plates in my TE450, I ended up grinding about 1/16" off the push rod, allowed the clutch pack to collapse fully and felt alot better.
