Bikerdad
Still breaking in the new bike only got ~150miles on her but have a few questions I hope folks can help me with.
Have a bit of a backfire coming off throttle, not all the time but fairly frequent. Too much fuel or is this common/normal for the bike.
Getting about 37mpg with mixed on and off road use. Is this low I ran out of gas on first ride
Was figuring I would be in the 40's. Running pretty much stock but dealer did adjust the std map to make it run better.
I would like to put a carrier plate on the tail of the bike (eg PMB or the like) Noticed that others mentioned using the TE 610 sub frame carrier bracket but may not fit on the 2010 bike. Has someone made this work or come up with another solution?
I need to do the first oil change but dealer does not have the filter in stock. Does it use the same oil filter as the 09 or is it something else?
Was figuring I would be in the 40's. Running pretty much stock but dealer did adjust the std map to make it run better.I would like to put a carrier plate on the tail of the bike (eg PMB or the like) Noticed that others mentioned using the TE 610 sub frame carrier bracket but may not fit on the 2010 bike. Has someone made this work or come up with another solution?
