Stephen
Hello, I just purchased a used 2010 TE 250 last week, i knew the owner of the bike very well in which he kept the bike mint and had all kinds of extras on it. Yesterday i went to go for a ride and the bike would not start, it fire up and then die once and then just never ran again. I let it sit for an hour and kick started it and it would only start with using the hot start lever, it would not idle..or it idle too low and would stall when i would ride it i could not let it idle or it would die. This bike has the jd power surge 6x in it. Some time the bike does not like to start with the electric start it just cranks, i have only had this bike a week if that so any advice is great cause i have not even put 5 miles on the bike yet and am itching to go for a rip!
Thanks for reading!
Stephen
Thanks for reading!
Stephen
on my 450)>> so I am not sure but> That is not a "hot start" that's a manual decompression lever on the bars. The bike has auto decompresion as well so most never use the manual decomp- maybe to turn it over/ cycle while kick starting or to clear after water intusion... but not much- it should not be needed for normal starting. Unless your talking about the air bypass knob (high idle knob). If it only starts with that- I'd say your idle is set way to low (should be 1900--2000.
