2010 TC250 piston ring replacing
ray_ray
Mini-Sponsor
One of my TC250s (~215 hrs) needs rings I guessing as the engine oil is going somewhere at a somewhat high rate (I feel) ... Bike still runs well and has power, but the oil is disappearing ...
I've looked at the repair manual and don't see anything too difficult at this time but have the following questions on the subject ..
1) Can I just remove the head and cylinder and then replace the rings with the piston left attached to the connecting rod?
2) The head and base gaskets are made out of metal. Can these gaskets be used a second time or is that risking too much.
Thanks for any help here.
Yes to the 1st question. An I wouldn't to the 2nd question unless you really had no choice. If you do reuse the gaskets spray them with something like this http://www.permatex.com/products-2/...-copper-spray-a-gasket-hi-temp-sealant-detail
Don't reuse the head gasket, if its like mine, its not copper/reuseable, its a coated metal, and the coating will most likely separate from the metal when disassembled, I've re-used head gaskets on my Harley, but those are actually copper-based gaskets.
