125-200cc 2010+ exhausts fit 99-04 cr125?
yzrider
Ive got an 04 cr and wondering if i can use 2013 exhaust on my bike. Seeing many used full exhausts for sale cheap and i cant even find any really for the 04.
Is it close? Little massaging needed? Any help much appreciated. Looking to add some italian ponies for next year.
You will need to move the mounts a bit and the silencer has a different length tube. Certainly doable if you are good with a welder and cut off wheel on a grinder. You can get silencers for I believe a 2007 cr/wr125 and it will make mounting easier.
Best way around this is just to cut the stinger off your pipe and weld it to the later pipe then your good to go as its more the stinger shape than the rest of the pipe that differs, The front mount should fit without messing with it (they did on the ones Ive modded).
