250-500cc 2009 wr300 high compression head
jonnywr
Hi
Just got this 2009 wr300 was about to do a top end and noticed this number on head to what I believe is the high compression head?
Also has a B stamp does this indicate piston size?
The number in question is the one at back between hoses
Pic of bike
Ps I had one of these new in 2013 this 2009 seems more powerful everywhere.
As per the part number it really seems like the mystical 'race head' :
I tried as well to get that head in my hands back when I had the WR300 but it was impossible... In the end I had my oem head cut to a different dome profile that worked really good...
Regarding the letter B on hour head, I really don't think it has anything to do with the piston, maybe a different mold or something ...
Cylinder sizes (A or B) are sometimes written or engraved on the cylinder, but not cast as in your head, as this measurement is done after the fabrication and engraved or printed manually. On a lot of bikes this can be found inside the power valve compartments.
When changing pistons, always measure the bore to get the correct sized piston ;)
Cheers !
You’re correct that’s the hi-comp head. The b doesn’t mean anything. I do have a hi compression head if anyone is looking for one.
