Edit: See thread below, my issue was a cracked fuse, it was not blown, but cracked! Check your fuses very carefully and/or replace them if you have any similar issues.
Edit: Just saw this thread: http://www.cafehusky.com/forums/showthread.php?t=13795 seems like there is a good chance I have the same issue, I will check my fuses carefully and replace them for good measure tomorrow.
I have a 2009 SM510, was riding at the track yesterday and the bike completely cut out midturn. I figured it was low on gas, it wasn't. The fuel pump does not prime when you turn the ignition/kill switch on. The gauge cluster displays FAIL after a couple of seconds. All I can hear is a relay click, the rearmost relay on the left side of the bike. I verified that the fuel pump DOES work when you put 12v+ to it.
Haven't really done much else yet. I disconnected the tilt/tip over sensor and connected the two wires but it still does not work.
Any ideas?
Thanks
Any ideas?
Thanks
