2008 TE250 clutch question
Hello gang. I am new to the forum and new to the TE 250. I like the bike so far, but I have a question. I don't think the clutch fully disengages. If I try to start the bike in 1st gear(with the clutch pulled in) the bike doesn't like to start. Instead the whole bike lurches forward. The only way to start it is to give it some throttle.
I think this clutch problem also contributes to the engine stalling when I come to a stop.
I can't figure out how to adjust the clutch. I know you can adjust the lever for different hand sizes, but how can I get a little more free play in the clutch lever?
I apologize in advance if I posted this in the wrong spot. I did try a search and will continue to. Thanks in advance and let me know what you think. Scott
There has been lots of past questions on this dragging issue ... My 08 TXC250 is about like you described ... The only thing I have done to it to help in regards to the dragging, is use at least 1L of true synthetic engine oil. Using only dino oil makes it drag very bad...
I'm sure others have other solutions ...
Thanks for the answer. I guess we will live with it. I am trolling older posts for some other fixes for little problems. So far I think it is a pretty cool bike. Thanks again.
