125-200cc 2008 CR144 Linkage Bearing Question
offroadeast
I was in the shop yesterday all set to replace the swingarm/linkage bearings in my CR144 and ran into a problem. Like always (never on a husky though) I went to the arbor press and started to remove the old bearings. When I tried to press the bearings out through the bottom, the top bearing was crushed. After a bunch trouble I got the bearings out but there was some damage in the bore where the bearings were pressed out of. It looked like there was a spacer or shoulder between the two bearings in the linkage.
Is the bearing outer diameter straight through the linkage or is there a shoulder in the centre of the linkage that the bearings butt up against? If the bore diameter does not go straight through the linkage, is there a special bearing puller that I need to buy or make to finish the job?
I have replaced hundreds of suspension bearings and have never run into this before.
Yes, there is a shoulder in there. And the newer Hondas have one also.
You're supposed to use a inner, or blind bearing puller to remove them. I've been able to get them out with a drift in the past.
My buddy thought it was a dumb idea on his Honda, so I bored the shoulder out for him, so he can drive them straight threw.
Great, thanks for the info. I'm glad that I'm not the only one that ran into this trouble. I think I will Just set all the links up on the mill and clear out the shoulder.
Can the swingarm bearings be pressed right through, or do I need a blind puller for it as well?
Thanks again for the great response:notworthy:
