2008 Athena 310 Kit fit a 2007 TE250?
valkrider15
I've got a 2007 TE250 and have a line on a Athena Kit, but it is for a 2008. I looked at the parts fiche and the 2007 / 2008 stock cylinder and piston are the same. I have seen different part numbers for the Athena kits but wonding if the difference is just the inclusion of a different FI ECU and is the Athena kit for the 2008 will bolt on the 2007. From what I've found it looks like it will but would like confirmaiton from someone that KNOWS rather than me guesing.
Thanks!!
The kit will fit. The difference is the ECU for the 2008 & up fuel injected bikes. Just put the ECU in a box on a shelf somewhere as you won't need it.
I put one of these kits on my carbed 2009 TXC 250 last spring, pretty much the same deal as your 07 TE.
