Holland
Hello Everyone,
I've been working on getting some axle sliders. Since I'm a cheap cunt (after all, I'm Dutch) I'm doing that the cheapest way possible. So I ordered myself some skateboard wheels from China for €7, got some a threaded M8 bar, and selected some of my M8 nuts.
I quickly came to realise it wasn't plug and play. Of-course you can just more or less assemble them, but since everything about this bike is done right, I didn't want to make it look like a monkey wrenched those things on there. Since I'm a 4th year mechanical engineering student and have access to engineering software like Autodesk Inventor I came up with the following designs for spacers. My measurements of the bike's specifications and such are 100%, but ofcourse that doesn't mean it's 100% the same as your bike.
so what's important:
-fabrication at your own risk
-should fit on 2008-2010 Husqvarna 450/510 SMR
-you're free to use anything I post here, but please don't spread without my consent (or serial produce, the obvious stuff)
-If you'd want I can send the drawings / 3D models
-you'll need access to a lathe and lathing skills, or know someone who has/can
-units are metric.
-made to fit skateboard wheels with the following specs: outer diameter: 53mm, thickness: 30mm, axle inner diameter: 14mm, nut area inner diameter: 21.5mm, deepness of nut area inner diameter: 10mm
-any questions feel free to ask
-orientation in photo's is like you're riding it. braking side is right side, shifting side is left side, front tyre is front side.
tools and materials needed:
-2x hexagonal socket 13mm
-a lathe with aluminium blades for cutting, grinding and chamfering, and a drill-bit preferably exactly the diameter of your treaded bar (M8, 8mm-ish, mine was 7.9mm)
-a grinder with cutting plates for aluminium, or a milling machine, or basicly anything you can get your hands on to clean away excess metal of the Front Right Spacer.
-4x 40mm long Aluminium cilinders with a diameter of 30mm
-2x M8 locking nut, eg. DIN 934 (make sure they're not too "high"! DIN 934 or similar height will fit nicely!)
-2x normal M8 nuts, not too high but in general you'll have to worry about that with normal M8 nuts
-4x washer outer diameter 21mm, inner diameter 8mm, thickness: 1mm. Or make them yourself while lathing the Spacers like I did.
-4x skateboard wheels, axle inner diameter between 8 and 14mm, nut area inner diameter 21.5mm, deepness of nut area inner diameter: 10mm
-2x treaded M8 bar, approx. 400mm long
-a metal saw to saw the Bar to the correct length
-a calliper or other necessary measurement tools
-Locktite, very strong permanent one like Loktite 601
reference photos:
Assembly photo's
right front side
left front side
left rear side
right rear side
Specific pictures of spacers
right front side
left rear side
working sheets
complete with tolerances and everything you or your lathe-engineer will need to make you the thingies. Note that the inner diameter of 8mm is a reference to whatever real diameter YOUR M8 tread is. The given dimensions are optimal and tolerances indicate how you can derive from them.
washers
front right spacer
front left spacer
rear right spacer
rear left spacer
Continued in next post
-units are metric.
reference photos:
Assembly photo's
right front side
left front side
left rear side
right rear side
right front side
left rear side
working sheets
washers
front right spacer
front left spacer
rear right spacer
rear left spacer
