2007 te510 oil change
27rich
any thoughts. I did an oil change tonight and changed the paper oil filter on the right side. now filling it up the manual states 1.7 ltrs however after putting in 1.3 ltrs and running it for 1 minute it the oil is at a level that the oil comes out slowly from the oil level screw on the right side. my concern is that I dont want to be putting to little or to much oil in.
or do I just accept that since it is coming out of the level screw it is at the right amount regardless of oil quantity? ?
There's a little bit of oil left in the motor after a change, with 1.3l added in, you should be good to go for a short ride and then check it again.
